Oh ! This is interesting. I didn't know that. It may be a workaround even if it's less clear. That said, it would be ideal if instead of displaying a percentage, it displayed a number of days remaining
Eventually yes. It seems to me that it was the @CalebJohnβs idea to have a better integration with todo.txt
That would have the advantage of allowing to use a kind of widely used standard... probably better for mobile use in the future.
I agree that //YYYY-MM-DD~YYYY-MM-DD is a good replacement and I think having that ability to express a task as multiple days is pretty essential for a good task management system
I've previously used todo.txt and really liked it (I only dropped it because I couldn't find a good enough implementation with other apps), I think moving towards that would be a very good idea!
Nice, itβs the first plugin I try with filters
It would be beautiful if the filters will use existing things (notebooks, tags, dates) from Joplin. And also the possibility of selecting multiple tags in the filter options.
It will make the filters too complex for a panel with limited width (or height if you place it below the other panels). Three (or maybe Four) filters at the most for a clean UI currently.
I agree. However, I cannot create a suitable UI design for the multiple selection. Currently, all the UI elements are based on bootstrap, and the multiple selection in bootstrap takes up a lot of space Select Β· Bootstrap v5.2
You should really take a look at this plugin, the preview feature is something I really like, he's probably overlooked by most people, and if you're willing to add him to the toolbox it's really great.
Again, I feel that more and more plugins, the sidebar will also become bloated and take up more space, should you add selection settings that allow people to choose what they want, hide those that people don't need.
I have updated the plugin, I will try another of your plugins, thank you for your work.
One more thing, the to-do list in it, completely disappeared when I ticked it off. If I wanted to cancel, I had to go to the notes to find this to-do. Can I expect it to be displayed at the bottom of the todo, or add a filter for completed items?
This is something that would be useful. I often have todo with links in them. They are visually rendered but I can't click on them. This makes sense since the click leads to the todo. But if I could preview without clicking it would be great...
Technically speaking, yes. However, it can cause serious performance problem: The number of finished tasks keeps growing every day. So it is almost impossible to gather all the finished tasks together from all the notes.
The most possible solution I think is only keep the tasks in memory for the tasks finished in one run of joplin. If you restart joplin, then you can not find the finished tasks in the previous run of joplin.
Maybe allow clicking the link to open it as a temporary solution? Preview feature is much more complex, especially with a good user experience and beautiful UI
Another small question. You've completely converted me to using inline todo's with this great plugin. The only thing that is not yet ideal for me is the way to capture and sort your notes.
Currently, when I journaling, my meeting notes are under a title in the note of the day of the meeting. But if I write todos (without scheduled date) on the fly during the meeting they will not appear in "inbox" but as planned on the date of the meeting. I conclude that you don't note your tasks to be treated in the diary but in another one ? And if your unplanned todos are out of the "journal" notebook you move them to the day corresponding to the planning date once processed?
So I'm interested to know how you do it.
NB Β«1Β»: Another non-priority idea by the way... autocompletion of projects/tags
NB Β«2Β»: To support development, can we contribute somewhere?
You can limit the time, for example, to view only one week's completion history.
I think it's better this way, similar to Windows Recycle Bin and Joplin's note history, only saved for a certain amount of time, a lot of things are based on such rules.
