@shikuz Ok...so a few things...
First, I noticed that if I was last on whichever note was set as the home note, not only would I get the "can't find home note" message, but whichever note was used before the home note would load on restart instead as well.
Second, I did some stuff before seeing this and I thought I figured it out, but alas I did not. So while I had Home Note disabled, it was still installed. I removed it, and still had the same issue. So I deleted my home note and created a new one and it worked! It appeared that notes created AFTER removing Home Note would actually load at startup / restart, but the notes created before would still throw the same error.
So I let it be and got on here to update, saw your response, and opened Joplin to get that info....and the issue has returned like 10 minutes later...
I then did what you asked and disabled all the other plugins, restarted, and the error still occurred. I then re-enabled all the other plugins, restarted, and the home note loaded just fine...waited about 10 minutes like before, closed Joplin & reopened....and the issue is back again...
Anyways, here's the about with the full list of installed plugins:
Joplin 3.5.13 (prod, win32)
Device: win32, Intel(R) Celeron(R) N4000C CPU @ 1.10GHz
Revision: 0c1511f
Backup: 1.5.1
Better Tables: 1.0.0
CodeMirror 6 snippets: 0.1.0
Collapsible Sections: 1.9.3
Combine notes: 1.2.3
Editor Themes: 1.1.0
Extra Markdown editor settings: 1.11.0
Favorites: 1.3.2
Freehand Drawing: 4.2.0
Import local CSS: 1.1.0
Joplin debug tool: 0.3.0
Joplin Explorer: 1.2.2
Note list and sidebar toggle buttons: 1.0.3
Note Tabs: 1.4.0
Outline: 1.5.15
Quick Links: 1.3.2
Resume Note: 0.5.0
Rich Markdown: 0.17.1
Tagging: 1.0.3
Templates: 3.0.0
Wikilinks: 0.4.1
YesYouKan: 1.1.3
