Yes! See the pull request.
This looks awesome and adds so much value to the already great Joplin app! Would this also work on the iPad which runs on iPadOS?
Indeed I definitely am waiting for it too!
@npulidomateo if you want to try it you also can install the prerelease version as mentioned earlier on; it works side by side with the normal one.
The Android beta has been updated!
Most of the design suggestions have been implemented, so hopefully this will be one of the last prereleases.
