Multiple instances
This is not really supported at the moment. You can do so using the command line though using this command: /path/to/app --alt-instance-id alt1
On Windows or Linux you can create a shortcut for it. Maybe that will be a future feature - a way to create such a shortcut from the app.
It's enought for me !
I can create shortcuts for both instance, so no problem !
