Manual Pull Or Sync
a. add a config texbox to put the URL and add a Pull or sync button
b. on clicking pull or sync button, pull the text or md files and override the local content from the server.
I suppose your "issue" is meant as a feature request ?
Anyway, as far as I am aware of, Joplin (alone) does not support sync of one note. But a dedicated plugin may exist or wait around the corner. Did you check all plugins against your needs ?
Not a sync note but sync of all notes which resides in a URL or a folder path
