macOS
Joplin 3.6.15 (prod, darwin)
Device: darwin, Apple M4 Pro
Client ID: 523a5bd3545e46a29610793654e5ccf1
Profile Version: 49
Alternative instance ID: -
Sync target: (None)
Editor: Rich Text
Revision: c615726
Athena: 2.2.3
Backup: 1.5.1
Freehand Drawing: 4.3.0
OCR: 0.3.2
Dropbox
Status quo desktop (macOS): 2 profiles:
- Default (which appears to have been corrupted)
- New (the result of exporting the contents of Default and re-importing)
Status quo mobile (iOS): 1 profile, Default, which has been syncing via Dropbox
My collection of notes is large (2.5GB) so I'm planning to delete/empty the Default profile and just use the new one.
What's the most efficient/safe sequence of steps for handling that transition in terms of syncing with iOS and deleting the contents of the Default profile?
Should I, for example, delete the contents of my desktop Default profile and then sync that with my phone (so there's an empty Default at both ends) before attempting to sync the new profile?
