Location of Joplin installation
Joplin 3.4.12 (prod, linux)
Device: linux, Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz
Client ID: 24b1d66b90db44f79600adaec1d36861
Profile Version: 48
Keychain Supported: No
Alternative instance ID: -
Revision: e9a9f68
Backup: 1.4.3
Freehand Drawing: 3.1.0
OCR: 0.3.2
Publish to Web: 1.1.0
Remove Images: 0.0.2
Dropbox
Rich Text Editor
I just used the script to install the latest version, 3.4.12, and I have no idea where the app is installed. Is there a folder where the script placed the appimage?
If I need to remove, how do i do it?
Thanks
It should be in your menu alongside all of your other office software where Libra office is.
@ierotheo welcome to the forum.
~/.joplin
Just delete Joplin.AppImage or the whole ~/.joplin folder.
