Homepage    |    GitHub    |    API    |    FAQ
Joplin-vieweb: a simple web viewer for Joplin notes
Hello.
Presentation
I'm going to use Joplin as a notes application (instead of OneNote).
It's a long time I wanted for something like Joplin: opensource, not coupled to a web giant, and without illimited storage: storage has a price, we should pay for it.
This quick dev is to provide an online view of my Joplin notes.
It's running on a "Django server", running beside a configured & running Joplin terminal app.
It looks like Joplin:
joplin-vieweb-screenshot
Features and not(-yet?) features
Yes it does :heart:
  • Protect joplin-vieweb access by login
  • Display notebooks, and notes
  • code syntax highlight
  • Add a table of content if note contains headers
  • Display tags, and notes linked.
No it doesn't (yet?) :broken_heart:
  • Sort notebooks nor notes
  • Create / edit / delete notes or tags (but I will quickly add tag edition)
  • No specific handling for todos.
  • Search for notes or tags
Read more on
github/django-joplin-vieweb
so you're creating a web version for joplin?
Hello.
Mainly a viewer. I need to access my notes online.
About edition (create, edit, delete) of notes... not for now.
And I expect implementing tag edition, because I use them to find easily my notes (so if I cannot find one note fats enough, I want to be able to edit its tags).
will you be releasing this for general use anytime soon?
I've done.
If you visit the github page you'll find some instructions to install your own server.
On the readme, quick instructions for starting in a django project (if you're used to).
Or you also have a full step-by-step guide to setup a full web server for joplin vieweb (with nginx).
Nice work!
Hey just want to note that there is some prior art in this area:
Hello.
Yes I know, and I know it's more advanced.
And I started by trying it (you can read why not joplin-web? in my github).
I was a bit "shy" to post my app because the other exists, more-featured. My purpose is really not to "compete", but I thought it may interess somes...
I'm pretty sure that other project in not maintained so nothing to be shy about.
I tried it a year ago or so, it was working but slow to the point of being unusable. Maybe it was because I hosted it on raspberry pi.
Hey I just wanted to make sure you knew just in case! There are actually two joplin-web projects, the post-fork and prefork one, and I think the prefork was a bit simpler than the repo that's up there now).
You're doing great, no need to be shy -- you sharing your work with everyone is awesome :slight_smile:
Hello.
New version, that brings mainly the Jolpin sync feature:
  • background joplin sync to keep your server synchronised with your cloud
  • Manually trigged sync: usefull when you start using and testing joplin-vieweb.
Some screenshots:
image image
(yes, the 2 top tabs are flipped :wink: <=> cannot click during the sync)
I added some icons for attached files:
Hello.
New version 1.7:
  • Share notes with public tag with a public link.
  • Option to number (or not) header in notes (#14):
Upgrade
Wow nice work!!!
Hello.
New version of joplin-vieweb which handle tags edition:
Once tags edited, a little reminder not to forget to synchronize Joplin:
New version 1.9 of joplin-vieweb:
  • Checkbox lists changes can be saved or discarded:
    Once saved, a little reminder not to forget to synchronize Joplin:
New version with notes edition / deletion
New version V1.10 of joplin-vieweb:
Attachments and images are supported (drag'n'drop, or paste image from clipboard): a big thanks to easymde.
Install / update procedure here.
Next to come: note creation, but I needed note edition first.
Great project!
Is it suitable for using on a mobile phone?
Hello.
Thanks.
Well, it's not really a good UX on mobile: I did it with laptop or PC in mind, this is my use case.
Sometimes I use it from my mobile: it's usable, but not designed for.
Here is a screenhot for notebooks and notes selection:
And here a screenshot when you slide to right for note reading:
As you can see, you can read, but the interface is not responsive.
I think I'll do it one day, but it's not my main use case (Github enh).
Edit: I've just had a look to OneNote on the web on mobile to get inspired about mobile navigation between notebooks, pages and notes. In fact it's not well designed for mobile! Just use the mobile in landscape mode.
I tried with joplin-vieweb (I didn't get the idea before, shame on me;-)), and it's not so bad (the headers of the accordion overlap a little):
new version with note creation
New version 1.11 of joplin-vieweb that brings note creation feature:
joplin_create_note
Also displays the notebook or tag panel after synchronization is finished, and select and display the last selected note .
New release 1.12 of joplin-vieweb.
Main feature
notebook edition: create / rename / delete:
notebook_edition
Others enh:
  • After synchro, all is refreshed, and the last notebook / tag / note are selected again.
  • Create buttons are hidden while note edition
  • popups are nicer than default javascript alert / confirm
  • Notes list: an icon in front of each note
  • Note edition: side-by-side edition (markdown on the left, preview on the right) is possible without fullscreen.
