Joplin syncronizes about every minute instead of 1 hour is configured
Joplin 3.7.10 (prod, linux)
Gerät: linux, Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz
Client-ID: 1eed50a6815f40068dfd65e6e0b2dfaf
Sync-Version: 3
Profil-Version: 53
Unterstützter Schlüsselbund: Nein
Alternative Instanz ID: -
Sync target: Nextcloud
Editor: Markdown
Revision: 0d5d4c4
Nextcloud
System is Linux Mint 22.3 X11, Joplin is installed as .deb
Sync runs about once every minute or if I deleted a note, although I configured sync for a 1 hour intervall. Attachments ist set to "manually", I disabled "all" plugins. Same behavior with Version 3.7.9. Attached ist the file: /home/matze-mint-nb/.config/joplin-desktop/log.txt. I deleted it before updating to 3.7.10.
Log file
log.txt (88.5 KB)
I think it‘s the normal behaviour when you work with your notes. Joplin saves your changes to your sync-base timely to your work to avoid the risk to loose changes or to avoid unsynched changes that only exist on ine device. The intervall just gives a sync schedule when your app is active but you don‘t make changes.
It was my mistrake, I accidentally synced the Joplin Sync folder with my Nextcloud one more time using my Nextcloud desktop client. When I turned that off, everything was back to normal.
I don't know why, but sometimes the Nextcloud sync gets messed up after a Nextcloud Desktop update.
