I have deployed a webdav server with radicale (https://radicale.org/3.0.html). I have pointed Joplin to the correct https://mysite.com/radicale url and provided it with the correct credentials. However, despite authenticating fine, any actual sync requests return either 403 (for /radicale/info.json) or 404 (for /radicale/locks/).
Overall, it just doesn't work. My questions are:
- Has anyone used radicale as a syncing server?
- Is there a different URL I should be using than the global /radicale endpoint? Is Joplin smart enough to find the correct url?
- Do I need to setup anything in radiacle?
- Will radicale even work?
Any feedback is appreciated. Thanks!
