I've started developing a lightweight web client for Joplin called Jarly.
I've uploaded the current version of Jarly here : Package jarly · GitHub
please be aware that this is a very early version.
Configuring your docker container requires the following environment variables:
environment:
- JOPLIN_SERVER=https://joplin-server.invalid/
- JARLY_LOGIN_MODES=SSO,CREDENTIALS
If you want to use SSO you have to run Joplin and Jarly on the same domain (or a subdomain), so Jarly can reuse the Joplin session id. Using CREDENTIALS for login, you can login with your Joplin credentials.
The source code is available here :
I'd really appreciate any kind of feedback!
Regards
Max
