Joplin 3.2.8 (prod, win32)
Client-ID: 719f3c913ade4f8b840d16111aa1ee4c
Sync-Version: 3
Profil-Version: 47
Revision: d458648
Backup: 1.4.2
Freehand Drawing: 2.13.0
I have lots of keywords and like to highlight two or more in the keyword section in order they work as an database "and-query".
example keywords are black, red, round, square.
Highlighted is black and round. database qery is search for records with keywords black "and" round.
shikuz
2
I'm not sure this is what you're after, but you can combine tags in your search queries. For example:
tag:black tag:round
This query will search for notes that contain both tags.
The Joplin help page on searching may be of use to you.
Hello @shikuz and thank you for the hint, that was what I was lookin for.
You are right. I searched but not in detail.
Just highlight two keywords would be a smart solution though.
system
Closed
6
