Joplin 3.4.12 (prod, win32)
Device: win32, AMD Ryzen 7 5800H with Radeon Graphics
Client ID: b4223f63eed946bcb2bd594f6c77c80b
Profile Version: 48
Alternative instance ID: -
Revision: e9a9f68
AlertsPerfect: 1.0.1
Backup: 1.4.3
Cursor Sync: 2.1.0
Embed Search: 2.0.0
Extra Markdown editor settings: 1.11.0
Freehand Drawing: 3.1.0
Frontmatter Overview: 1.1.0
Hotstrings & Hotkeys: 1.0.1
Markdown Table: Sortable: 1.3.0
Math Mode: 0.8.2
Note overview: 1.7.1
Note Variables: 2.0.0
Pseudocode Support: 0.1.0
Quick Links: 1.3.2
Recipe Scaler: 0.9.2
Resource Search Plugin: 0.1.2
Search & Replace: 2.2.0
Templates: 2.4.0
Text Colorize: 1.2.5
Is there a built-in way or a plugin that will let me reuse an image rather than dropping the same image into multiple notes from disk? I searched the forum, but didn't really see an answer. I see the same image with different ids in the resources directory. Wouldn't it be more efficient to browse to an image to reuse the link?
