[iOS/iPadOS] First input candidate invisible in light mode with external Bluetooth
If this is a bug report, please create it on GitHub instead. Follow this link:
on
iOS
OneDrive
Rich Text Editor
Environment:
  • Device: iPad
  • OS: iPadOS 17
  • Joplin version: 13.7.6
  • Editor: Rich Text Editor (the new web-based editor)
  • Input: Apple Pinyin Chinese input method + external Bluetooth keyboard
Bug description:
When the iPad system is in light mode and I type Chinese with a Bluetooth keyboard in the rich text editor, the FIRST candidate word of the input popup cannot be seen. It looks like the text color blends with the background.
In dark mode, the candidate shows normally.
This issue only happens with the Rich Text Editor. If I switch to the old plain text editor, the problem disappears.
The on-screen soft keyboard does not trigger this bug easily. Other apps (Notes, etc.) work fine under the same setup.
Steps to reproduce:
  1. Set iPad system to Light Mode
  2. Open Joplin, create a note, use Rich Text Editor
  3. Connect Bluetooth keyboard
  4. Type Chinese characters, check the candidate bar
  5. The first candidate is invisible
Expected behavior:
All input candidates should have proper contrast and be visible in light mode.
