Greetings,
I've imported all my notes from google keep without any hitch except all of my text is black. Since I'm using a dark theme on Joplin, The text from keep is barely visible. How can I fix this without having to change my theme to light which I won't do?
Sorry, Here is the source from a keep imported note:
<en-note STYLE="word-wrap: break-word; -webkit-nbsp-mode: space; -webkit-line-break: after-white-space;">Managing Pure-FTP Virtual Users<br/><br/>Managing users from the command line is pretty simple. Note that Pure-FTPd users can alternatively be managed using a MySQL database. That topic is not covered here but should be considered if you want to optimize management of thousands of ftp users on your sever.<br/><br/>Here are the commands (you can script them) to manage your users. Be sure to replace $USERNAME with the actual user id of the individual user.<br/><br/>Creating the First User<br/><br/>sudo pure-pw useradd $USERNAME -u ftpuser -d /home/ftpuser<br/><br/>sudo pure-pw mkdb<br/><br/>… if creating an admin user with full access to the server, omit the -d /home/ftpuser parameter which would normally causes this directory to become the root of the users ftp session.<br/><br/>Creating Additional Users<br/><br/>In chroot jail:<br/><br/>sudo pure-pw useradd $USERNAME -u ftpuser -d /home/ftpuser -m<br/><br/>Not in chroot jail:<br/><br/>sudo pure-pw useradd $USERNAME -u ftpuser -D /home/$USERNAME -m<br/><br/>View a User<br/><br/>sudo pure-pw show $USERNAME<br/><br/>Change a User's Password<br/><br/>sudo pure-pw passwd $USERNAME -m<br/><br/>Update an Existing User<br/><br/>See Pure-FTPd documentation for a list of options to replace $OPTIONS.<br/><br/>sudo pure-pw usermod $USERNAME $OPTIONS -m<br/><br/>Deleting a User<br/><br/>sudo pure-pw userdel $USERNAME -m<br/><br/>Listing All Users<br/><br/>sudo pure-pw list<br/><br/>Update the User/Password Database Manually<br/><br/>(in case you forgot the -m)<br/><br/>sudo pure-pw mkdb<br/><br/>Managing the Pure-FTP Server<br/><br/>Start Pure-FTPd Server<br/><br/>sudo service pure-ftpd start<br/><br/>Stop Pure-FTPD<br/><br/>Note: This does not disconnect active users.<br/><br/>sudo service pure-ftpd stop<br/><br/>Disconnect All Active Users Immediately<br/><br/>sudo killall pure-ftpd<br/><br/>Pure-FTPd Status<br/><br/>sudo service pure-ftpd status<br/><br/>Restart Pure-FTPd<br/><br/>sudo service pure-ftpd restart<br/><br/>View Server Activity<br/><br/>sudo pure-ftpwho<br/><br/>Changing the Welcome Message<br/><br/>This message is only visible to command line users and in some FTP clients. To see what your server currently displays, open a command prompt and type:<br/><br/>ftp ftp.yourservername.com<br/><br/>In order to customize or even remove this message, you must create a FortunesFile file:<br/><br/>sudo echo "/home/ftpuser/fortunes.txt" > /etc/pure-ftpd/conf/FortunesFile<br/><br/>In the fortunes.txt file, put any message you want to display or leave it empty.<br/><br/>Setting Pure-FTPd to Start-up When the Server Restarts<br/><br/>Important: You must do the following or the server will not recognize virtual users after you restart the server:<br/><br/>cd /etc/pure-ftpd.conf<br/><br/>sudo echo 'no' > PAMAuthentication<br/><br/>sudo echo 'no' > UnixAuthentication<br/><br/>sudo echo '/etc/pure-ftpd/pureftpd.pdb' > PureDB<br/><br/>sudo ln -s ../conf/PureDB /etc/pure-ftpd/auth/50pure<br/><br/>Virtual Directories<br/><br/>Pure-FTPd supports virtual symbolic links (a.k.a. symlinks) to directories in other palces on the server -- outside your home directory. For example, you can create one using the following commands:<br/><br/>Create a symlinks to each of the different areas on the server that they will need access to:<br/><br/>ln -s /var/www /home/ftpuser/www<br/><br/>To remove a symbolic link, simply delete it. Example:<br/><br/>rm /home/ftpuser/www<br/><br/>This will only delete the symbolic link and not the contents of the folder. Just be sure it is a symbolic link and not a mounded directory though.<div>
</div>
</en-note>
It's only this visible because I changed my them to solarized dark which I really don't like. I prefer the dark them but as I stated, black text on a dark them just doesn't work.
