Hi there,
I want to ask for tips here before possibly posting this to Github.
For me, Joplin 2.2.2 (Pre-Release) has a tendency to suddenly start devouring resources, and then crash. This usually happens couple of minutes after launch, and the devouring doesnt stop until Joplin crashes (Highest RAM usage I have seen is 10GB out of 16GB and CPU usage of 100% for minutes). This happens on MacOS 11.5.1 and Windows 10 May 2021.
Each time this happens console only prints one line dozens of times per second:
PluginRunner: Got message (3): joplin.data.get ["search"] {query: "iscompleted:1", fields: Array(4), page: 0}
Here's a list of my plugins:
Conflict Resolution 1.2.0, Favorites 1.2.1, Kanban 1.0.0, Markdown table calculations 1.0.3, Note Tabs 1.3.0 , Repeating To-Dos 0.0.1, Simple Backup 1.0.2, Tags Generator 1.0.0, Untagged 2.1.1
My question: Is there a better way to trace what is causing this behaviour rather than just toggling plugins on and off one by one and hoping that the crash happens? Because I haven't reliably been able to reproduce the issue, it's just usually happens sooner or later. So whether I use Joplin, scroll, edit, sit idle, use any of the plugin functions... does not seem to have any connection to the issue, or at least so far I haven't been able to pin it.
Any tips? Or is it just "trial & error".
Thanks a ton,
Niilo
