macOS
in the documentation of embeddings it is said that we can disable embeddings but we have to remove index manually,
where is it located ? what should be removed if i decide to completely stop using embeddings ?
Thanks
Part of documentation :
Disabling the indexer
You can keep AI chat on but turn off the indexer by unticking Enable the embeddings indexer in Settings → AI. The model stays downloaded but no further indexing happens. Existing index data stays on disk; remove the AI profile data manually if you want to delete it completely.
