I think it should be 7.0.0 based on this:
https://mvnrepository.com/artifact/com.android.tools.build/gradle/7.0.0
Now I am getting this error:
Starting a Gradle Daemon, 1 incompatible and 1 stopped Daemons could not be reused, use --status for details
> Configure project :app
WARNING:The option setting 'android.jetifier.ignorelist=bcprov' is experimental.
WARNING:DSL element 'dexOptions' is obsolete and should be removed.
It will be removed in version 8.0 of the Android Gradle plugin.
Using it has no effect, and the AndroidGradle plugin optimizes dexing automatically.
FAILURE: Build completed with 2 failures.
1: Task failed with an exception.
* Where:
Build file '/home/rishabh/Documents/contribution/joplin/packages/app-mobile/node_modules/joplin-rn-alarm-notification/android/build.gradle' line: 25
* What went wrong:
A problem occurred evaluating project ':joplin-rn-alarm-notification'.
> Plugin with id 'maven' not found.
* Try:
> Run with --stacktrace option to get the stack trace.
> Run with --info or --debug option to get more log output.
> Run with --scan to get full insights.
2: Task failed with an exception.
* What went wrong:
A problem occurred configuring project ':joplin-rn-alarm-notification'.
> compileSdkVersion is not specified. Please add it to build.gradle
* Try:
* Get more help at https://help.gradle.org
Deprecated Gradle features were used in this build, making it incompatible with Gradle 8.0.
You can use '--warning-mode all' to show the individual deprecation warnings and determine if they come from your own scripts or plugins.
See https://docs.gradle.org/7.3.1/userguide/command_line_interface.html#sec:command_line_warnings
BUILD FAILED in 1m 30s
