Fractional Scaling breaks the link creation with alt + drag and drop
When fractional scaling is enabled the alt + drag and drop function doesn’t work any more.
I am an Ubuntu 19.10. To reproduce this activate fractional scaling with this command:
for X11:
gsettings set org.gnome.mutter experimental-features “[‘x11-randr-fractional-scaling’]”
for wayland:
gsettings set org.gnome.mutter experimental-features “[‘scale-monitor-framebuffer’]”
Then go to Settings -> Display and choose a fractional scaling factor like 150%.
I don’t want to be dismissive, but don’t you think it could have anything to do with the fact that this feature is experimental? It even says so in the command you posted.
Please open an issue with gnome and Electron.
