- Reorder notebooks
- Display notes like in Keep
- Display first line of body in notebook list for notes without titles
- Edit note by tapping in body (i.e. don’t require tapping edit icon)
- Set default notebook for new notes to be assigned to
- Set default for making new note or to do, with ability to do the other either with a long-press or after creating the note. The majority of my notes are notes, not to-dos, so the current two-step method is a bit annoying
- Sort mode for showing most recently accessed notes first, regardless of whether they were modified
- Option to sync whenever changes are made
- Search function isn’t very good. Doesn’t search as you type and doesn’t match partial words, e.g. can’t search for “note” and find “notebook”
- When exiting configuration without saving changes, it should prompt. I thought dark mode wasn’t working then realized I didn’t hit the save button.
- Word wrap keeps changing while typing, causing text to shift back and forth which is very distracting and confusing, making it seem like autocorrect is making changes
