If you are actively using tags, a very handy feature would be to pin your favorite tags at the top so you can refer to them quickly. I usually solved this problem by adding some symbol in front of the text: -, · or invisible filler ᅠ
This brings the tag to the top of the list. But it would be more convenient to set favorite tags or manually change the order in which they are displayed.
