I would like to export my notes on my HDD which is not running my operating system.
When I want to export, I have only the choice of my SSD folders. I could export to a folder on my SSD and then cut-paste it to my HDD but this is not very convenient.
My HDD shortcut also doesn't appear when I want to export.
Could you help me ?
Thanks
Joplin for desktop 2.6.10 (prod, Linux)
Linux Mint 20.3
I believe that the save / save as dialog is a part of the OS and not Joplin. However I have noticed that with Mint the left pane of the save dialog lists the mounts of other disks under "Other Locations" and not in the sidebar.
In this case my second hard disk is labelled "JOPLIN_DATA".
EDIT:
Forgot to mention that if you open the Mint file manager and bookmark the second drive (or any folder within it) it will then show in the save / save as dialog side bar.
It's not in the repos. Just go to https://joplinapp.org and get the official install script for the AppImage.
I suppose it could be something to do with flatpak and/or the fact that your drive appears to be NTFS formatted? I am afraid that I am all out of ideas...
