I have the move to notebook shortcut enabled by adding
"command": "moveToFolder",
"accelerator": "Ctrl+M"
to the keymap.json and I find it very useful. However, it's only available when the editor is focused, so I often have to click into the note, toggle it from viewer to editor and only then I can use the shortcut.
Would it be possible to enable it in the viewer as well?
