Double notebooks
macOS
Joplin 3.3.12 (prod, darwin)
Just started using Joplin. I exported all Evernote notebooks without problem. I then tried to sync via Joplin Cloud basic, but found many attachments did not sync because of a max object size. I tried to use a NextCloud service but it was painfully slow, so I went back to Joplin Cloud but upgraded to Pro. Works well but now I have 2 copies of every notebook. I tried deleting one of each copy, but when I sync with other devices (another mac or iPhone) I still get doubles.
Ok, reset all devices but the original. Deleted the double and sync'd again. Problem is gone.
I had the same problem with Dropbox sync many times as well, sadly
