Corrupted Cursor With Joplin Flatpak 2.12.15
Lenovo Duet 5 running Crostini (Linux aarch64/arm).
Only flatpak Joplin works. Have been successfully using Joplin 2.11. Today flatpak updated to 2.12.15 and there are several big problems:
  1. The cursor is corrupted. Rather than an arrow, it is a large blurred box with what appears to be an arrow in it. I tried different cursor settings and get the same result.
  2. In the upper right corner of the window there are no controls to minimize, maximize or close.
How can I revert to an earllier version or fix this behavior?
Thanks
Update: Tried to uninstall and reinstall Joplin flatpak. Install was successful but when I try to run I get this:
error: app/net.cozic.joplin.desktop/aarch64/master not installed
Consider reporting this as a bug on the flatpak's GitHub repository -- it's maintained by a different group of developers.
Be sure to include what desktop you're using (e.g. GNOME/Wayland or GNOME/X11).
Done. Thanks.
There is an update on flathub from this morning that fixes the issue under the name net.cozic.joplin_desktop. This version works on my Chromebook under crostini
The prior version name was net.cozic.joplin.desktop (with a . instead of _).
Thanks for the quick fix.
