iOS
Joplin Cloud
Dear Joplin Team,
I am at my wit’s end. I migrated from Evernote to Joplin and have been experiencing constant sync issues ever since.
What I did:
Imported all notes from Evernote to Joplin on my MacBook and connected it to Joplin Cloud. Initially, encryption was enabled.
Installed Joplin on my iPhone and iPad Mini, connected both to the same Cloud account, and synced.
From day one, I received errors on iOS: "Some elements cannot be decrypted" or "Invalid property format".
Troubleshooting steps already taken:
Deleted and reinstalled the Joplin app on all devices multiple times.
Disabled the "prevent deletion if remote is empty" setting on iOS to force a clean sync.
Deleted all .config/joplin-desktop/ files on MacBook.
Disabled encryption entirely.
Used Victor plugin to completely wipe Joplin Cloud (reduced to 30 KB).
Re-imported all notes (6 GB) from scratch on MacBook and synced to Cloud.
Disabled the 90-day note history retention on all three devices before syncing.
Spent days re-syncing with the screen on, causing multiple app crashes.
Current situation:
No errors on MacBook – everything works fine there.
Persistent errors on iPhone and iPad Mini with the following revision IDs from the log file (log.txt):
2026-05-03 19:55:34: Synchronizer: Sync: createLocal: remote exists but local does not: (Remote 67c7dca0648547478dccb0a628ea4a7e.md)
2026-05-03 19:55:34: Synchronizer: Sync: createLocal: remote exists but local does not: (Remote 2cbdb26527ee4a90b4ca6394a5fa9159.md)
2026-05-03 19:55:34: Synchronizer: Sync: createLocal: remote exists but local does not: (Remote 77bc16a585ee423aaf12f763271c630c.md)
2026-05-03 19:55:34: Synchronizer: Sync: createLocal: remote exists but local does not: (Remote 7b0a260d76154483bed1eaaa3d3179b0.md)
2026-05-03 19:55:34: Synchronizer: Sync: createLocal: remote exists but local does not: (Remote 1a103569398e4b7399b0faf3b6d556dd.md)
What I need:
How can I identify and delete the notes associated with these revision IDs?
I only have the IDs from the error messages.
I searched the log.txt file but only found the above lines.
Why do these errors persist even after a complete reset of apps, local data, and Cloud?
Device info:
Joplin Mobile: 13.5.3 (prod, ios)
iOS Version: 26.4.2
Client ID: 1e6c8c262502476d80730fcad68809df
Profile Version: 49
Keychain Supported: No
Joplin Cloud Account: Pro
Total Cloud Size: 5.94 GB (20% of 30 GB)
Logs:
Available upon request (I can provide the full log.txt if needed).
I would be extremely grateful for any help to finally resolve this. Thank you in advance!
Due to forum restrictions for new users, I can only attach one screenshot. I can provide the remaining four screenshots of the error messages upon request.
