This is awesome, thank you!
As an extension - what do you think of following dialog appearing when you select multiple notes and press "Tagging list" button (akin to Evernote):
source URL (one of the pictures I could find with google "assign tag dialog"). "=Vorlage", "=Zeugnis" etc. are the tag names.
The main points are:
means all selected notes have this tag.
- Uncheck will remove tag from notes.
- Check will add tag to notes.
means some of the selected notes have tag
- Uncheck and Check will add tag to notes.
means none of the selected notes has tag
toggles, if you can see (and add) tags that are not assigned to any note at all.
allows to create new tags, which can then be added to selected notes.
This is one of the Evernote features, I honestly miss for organizing/tagging multiple notes. I have thought to implement this myself, though you seem to have quite advanced with your plugin.
