Can S3 storage specify a path?
S3
When I open my S3 storage object, there is so many xxxx.md files and .resource folder and .sync folder at the root path.
May I create a folder called "Joplin", then storage these files and folders in "Joplin" folder?
This way, I can still put some other things in my storage bucket without it looking cluttered.
I don't think there's a way to specify a path, you only specify the bucket to sync with
Is there a reason you can't create a separate bucket? this might depend on your s3 provider, but s3 pricing is typically based on your usage across all buckets, so creating a separate bucket likely wouldn't incur additional costs
