Argon2 synchronization encryption algorithm
Hello! The encryption algorithm for synchronization, Argon2, please add!
And, on Android, iOS, too.
I think a lot of people would be interested in this.
Good luck)
Argon2 is a key derivation algorithm, it can't be used to generically encrypt data, it encrypts (or more, generates on the fly) the key that encrypts the data done by a different algorithm.
For example, my password manager (KeepassXC) uses Argon2 to derive the key used to actually encrypt the passwords, which is done via AES.
