Android 8.1 To-do alarm not saving
App version is 1.0.307 on Android 8.1
Sync to Nextcloud.
If I create a new to-do the to-do will save automatically. If I tap Set an alarm - I select the date and time. It will only very briefly show in the ‘Select date’ window and then disappear. Tapping the ‘Save alarm’ button after that will not save the alarm of course.
I sync with my Desktop PC and the To-do will show on the PC, confirming that no alarm is set.
It’s now tracked here: https://github.com/laurent22/joplin/issues/1958
As you were unable to replicate, I decided to uninstall and reinstall. That fixed it!
I now realise I should have tried that first.
Thanks for all your work, it’s a great app!
